skoda fabia key cutting - programing
Hi,
can any one help me? i tried to program a skoda fabia 2000 key transponder with a vag-tacho 3.01 on the software it said that everything went ok but the 'immobilizer light' will not stop blinking (i even disconnected the battery as well - no effect).
Whats worst it does the same with the original key as well. the car turns on and runs but the light does not stop blinking.
i'm afraid it might stop running in the middle of the road.
any advice is very much appreciated.
P.S. the key cutters asked for £100 to fix the problem and i don't have that much to spare [/size][/size]
If Your cars engine doe’s not stop, then immobilizer accepts keys. You have to get a VAG-COM and check, fix and clear fault codes.
