Just ordered: Green Panel Filter
Hey all,
Just thought I'd say that I just ordered my first upgrade for my furby, a green panel filter for the princely sum of
It's a good deal alright!
I believe it was Neo VR who kindly let us know.
Cheers Jon, and cheers Neo for pointing me in the right direction :thumbup:
Fitting is dead simple.
Undo the 2 screws on the right hand side of the airbox. Un-hinge the lid of airbox & lift up (if you wish, you may unclip the intake pipe from the lid). Pull out the original filter & drop in the green filter. Drop the lid back down into the hinges & replace the screws.
Simple as that!
That's what I like to hear.
Just to point out that the green filter may not sit as snuggly as the original.
If so, then it may need to be moved around for a better fit.
What does that green filter do for a standard car? I read somewhere there was no need to replace the air filters on diesels as it has virtually no advantage... and can even be worse in some cases.
:rofl::rofl:
your wrong!
TDi engines use higher boost than a petrol... so sucks more air. you may not notice any power increases.. but i can tell mine is dirty as my car smokes alot more now :cool:
But if theres no power increase, then to me that means it doesnt really do much...
Hmmm, same here :confused:
I would have thought the Cupra ducting on a standard airfilter would be sufficient...
When I fitted mine, it made the engine sound a bit more purposeful up front - deeper note and with windows down, you can hear it drawing air through it, and it helps take away a little more diesel clatter. My Milltek is running in well too, and the whole package sounds really quite sporty! Seriously! :eek:
