service
car going for a service they say i need my brske fluid changrd is it worth gettinh it changed and does the clutch yous use the same fluid will i notice any difference .can any one tell me where the power steering fluid gose my superb is a taxi done 50000mls
Do you have a Superb II?
yes 1.9 tdi 59 plate
Then yes, the brake fluid should be done every 2 years.
You don't have any PAS fluid.
Brake fluid is hygroscopic, that is, it actively absorbs water from the atmosphere. This water can cause the boiling point of your brake fluid to be seriously reduced, the water content if excessive in brake fluid can also attack some of the materials of the braking system particularly alloy ABS/ESC units causing premature failure.
Please have your brake fluid changed at the recommended intervals, it is a safety critical procedure.
thanks guys get it done when cars in on monday for its servive :thumbup:
