Need help with the Skoda Octavia 1.9 TDI
i need help , my skoda octavia 1.9 TDI  automatic transmission now only move backwards,
gear 1,2, 3, & D disabled
  • Replies 50
  • Views 15.9k
  • Suggest start with a new thread telling us what you have done in terms of investigations.   However to get the ball rolling - have the car scanned for fault codes.  Check for vacuum leaks.  Check th
  • Obvious problem is usually sticking turbo veins.   A much easier and cheaper thing to check is your vacuum lines, they are all the small black braided lines running around the engine bay. Check thro
  • err why did he replace the timing belt and intercooler? Seems a bit weird, and unlikely that the IC would be damaged. Same with Timing Belt, it is something worth replacing yes, but I don't know that
