Holding the DSG on the brake...
8 members have voted
  1. 1. How long do you hold the 6 speed DSG on the brake...
    • Over 2 minutes and have seen the clutch overheat warning
      0%
      0
    • Over 2 minutes but have never seen the clutch overheat warning
      12%
    • Over 1 minute and have seen the clutch overheat warning
      0%
      0
    • Over 1 minute but have never seen the clutch overheat warning
      25%
    • Over 30 seconds
      0%
      0
    • Over 20 seconds
      12%
    • Over 10 seconds
      12%
    • Never, I put it into 'N' as soon as I stop moving
      37%
Please sign in or register to vote in this poll.
I'm just curious as to other experiences... the manual states the car can be held on the brake for short periods, such as when at a crossroads... but that's a pretty vague statement. So, it's over to you...
If I know I am going to be stationary for any more than say 20 seconds, I'll slip it into N. that way I can take my foot off the brake. You should not under any circumstances allow the car to be in D with the handbrake only applied as it will destroy the clutches.
Thanks, I probably move to N less than 20 seconds after I have stopped, but then if I'm crawling out of Manchester in peak hour I seem to end up changing from D to N and back again... it almost feels like I'm driving a manual (apart from the clutch of course).
So is there actually a difference between holding the car in D with the foot brake, and holding it in D with the handbrake? Mine just seems to want to pull whichever brake I use, hence moving it to N quite early.
Edited by Superbalicious
in D on the handbrake only the clutches are fully engaged and will be slipping if you are going nowhere, whereas in D on the footbrake you may feel some drag but the clutches are disengaged. The drag you feel is the oil between the friction surfaces, almost but not quiet like the way a torque convertor works in a traditional auto. Left in D like this the oil will heat up and eventually cause the overheat. Saying that I have spent many an hour crawling round the M25 using only D with no problem (typical stop/start with only short pauses).
So......Neutral is your friend!! :thumbup:
Ok, so N is best, followed by D with the foot brake for short durations. D with the handbrake is simply a NO-NO...
Cheers all :)
