will 15" alloys fit on the Vrs
have the new vrs's got 288mm brakes same as the mk1's ? If so in theory 15" should fit
Yeah they are 288mm and the spare is 15 inch so as long as your not running some weird et they should fit
The spare wheel on the Fabia Mk II Vrs is:-
5x100
ET 43
195/55/15" tyre which is the exact size to replace the 205/40/17
I think the wheels trevor is selling are 7x15" and the ET is 38
So will they fit??
et38 will be 5mm more out then 43, so if anything more clearance then thats good
Brakes are actually different - they are the same 288mm but calipers/carriers are different to the MK1? Look like MK4 Golf ones, so in theory you can change the carriers and discs for 312mm's.
the mk4 golf 312s and calipers are a direct swap if you want an upgrade
