18s wheels
will a 18s vrs fit on a roomster
You mean 18's from an Octavia fit on a Roomster? No idea, this is the Fabia section :D
Not sure what the PCD is on a Roomster...
roomsters same as fabia mk2 5x100
Roomster has Octavia rear beam? Must be a MK1 rear beam then...
believe its vitually a mk4 golf rear beam and fabia mk2 same front setup
Or does he mean the VRS's 17's?
I think the Octavia wheels have a PCD of 112 mm, not the 100mm PCD that the Fabia requires.
thanks for the info guys i now aim on the fab side ive got the sport fab at the moment but orderd a roomster only i need more
room sumone told me you can fit 18s on roomy so i ask on here these more info guys on here thanks again pete
That's a really long sentence.
as long as they're 5x100 they will fit, but you need to check the offset. same as fabia wheels so probably the same offset.
