Cost of wheel alignment
I paid £114 (£95 + vat) for front wheel alignment at an independent VAG specialist today. Is this excessive?
??? Which alignment? The both wheels facing the same way alignment? Or camber alignment?
Didn't think you could do camber on vRS?
It's usually £20 for wheel alignment! :o
I paid £35 for 4 wheel alignment on a John Bean (primary only) - Secondary variables would have cost a lot more. Do you know what they measured?
I don't actually know what they did - I assume both front sides were done, but the invoice just says "wheel alignment". I phoned them up and it seems that £95 + vat is their standard charge - they said that it "takes about about an hour" of work. I don't mind paying a fair price but I hate feeling ripped off.
That seems very expensive. Most garages will do it for around £50. From what I understand the camber cannot be adjusted on a vRS.
J
holy pooop!
got mines done for £15... took them about 30mins and they used top range laser equipment...
you can only do the front wheels on a fabia anyways, rear beam cant be adjusted
mines was only tracking / alignment... no camber adj.
Seems a fair price, I paid £85 for the alignment on my Clio, including camber adjustment which all took 1hour.
I was about £28 at Kwik Fit, that was with them using the laser set up aswell, about an extra 30mins to align the fronts
Despite the danger of my getting roasted for saying this, I'd reckon that your VAG indie carried out what that model of car needed and that is essentially a full four wheel alignment check and adjustment where possible.
Thats what VW charge... the fact that if you go to an indi' with top equipment and they do the same thing (some cars certain things can not be adjusted unless you remake certain components!) their charge will usually be around £50 for all four wheels!! :S There is a web site called alignmycar?? which has good indi's on it...my local that I use is on there!! B)
Edited by fabdavrav
2 garages near me are £27 (farmers) computerised system or £30 (HIQ) it think laser. However farmers in Edinburgh said they would put it on their special computerised jig that'll do full geometry checks for around £50. HIQ said they won't do my audi for £30 though because its really difficult if the track-rod ends are seized, so it would be £30 plus labour. Mine were so I had to replace them first (night-mare diy job). Mike07vrs not to be slanderous but your alignment is probably worse now.
Edited by The Worm
