Pikey short shift quick mod
I've had the TTS short shifter on my VRS for a good while now, but always wanted to do something about the length of the actual gearstick. So at lunchtime I swallowed some brave pills, lifted up the gaitor, unclipped the gearknob and removed, then fetched the bolt cutters.... :o
Two seconds later I had a gearstick about 35mm shorter, and then it was a case of 'see can I put it back together again' :giggle:
And yes, with a few thumps, the gearknob slid all the way down...a good crimp with a tile snips on the original clip, and all is dandy!!
Apologies if this has been done before, but I'm quite chuffed with myself :)
sounds interesting lol - piccies???
+1
No before pics :doh: , charged into it without thinking lol
After 'chopper' had been at work:
The single clip that needs undone and then reused or replaced:
And the finished article:
:D
You are truely mental! :clap:
Interesting that the gater surround and ashtray cover are silver, is that 'Paddy' spec or have you sprayed the bits in another moment of skodaphile madness.....? :rofl:
A fair few of the Fabia guys have done the same thing.
Mental I be. :yes:
The silver bits are painted, yes-used a trade range of plastic coatings called Bradleys-they specialise in smart repair supplies. Prepped, primed twice (primer also has a filler in it to give a smooth finish), sanded with some 2000 wet & dry, then painted. The shiny bit was masked carefully and cleaned off afterwards with some thinners.
Genuine bits were about £70 IIRC :o
Paddy spec FTW!!!
FTW??
'For The Win'
'For The Win'
:S
'For The Win'
That's the polite version anyway. :rofl:
Paddy pikey mods rule, OK? B)
Think I'll publish a guide: 'How to modify your car with a bolt cutters'
:D
Does the other version involve doing something to the world?? ;)
:x
FTW = fook the world
FTMFW = fook the mother fookin world
:D :D
will this work with my DSG. want to make the the gear change is so much faster........
this was a joke
Edited by janner_Sy
Holy feck, brave pills???? or ecstasy pills?? :giggle: :giggle: does look better though
I like pikey mods
:thumbup:
:thumbup:
what are your recommendations for the short shifter ??
I would like to go for it ....but I have heard that the length between N and 4th gear is uncomfortably short and it causes shifting problems !!!!!
is this true ?
I had a short shifter on my vRS for 40k miles.
Never ever had a problem with it
