Clutch pedal issue?
I need some help diagnosing an issue when I accelerate the clutch pedal goes down an inch or so then when I let off it comes back up there is no clutch slip as it is a new clutch fly wheel ect it's been bled but it was doing it even before I changed the clutch so it's not the clutch could it be the clutch master cylinder ? If so does anyone know a part number ?
Thanks in advance
Simon
Sounds like the clutch return spring on the pedal box is loose or broken.
So how do I fix that?
It needs a special tool, and is ultra fiddly to do. Impossible to explain, but it is covered in the Haynes and Skoda workshop manuals.
The clutch pedal housing welds can also fail, so worth having them checked as well.
Thank you I will look at that
have fun if its the clutch pedal housing did one on a golf wasnt very nice job. you may find you need 3 hands :giggle:
After spending the last 5 days doing the cam belt water pump fly wheel aux belt drop links oil change coolant change brake fluid change nothing phases me lol
Anyone know the part number for the clutch pedal master cylider ? There are a few on eBay but not sure which I need
Is there some where I can get a list of part numbers for my car?
Vagcat?
Matt
Still can't find the part number any ideas
