Clunky Coilovers
Hi Folks
had coilovers for a few weeks now and happy with ride and handling but they are clunkey and noisey at low speeds - thought they would settle in but don't seem to be improving - cant see that anything is knocking but don't know --
anything I should be worried about or is this the norm for new coilovers - read somewhere that other also noticed some noise at lower speed
cheers
How much did you lower it?
What make are they?
Vmaxx Coiovers with shortened droplinks - lowere about 45mm
Check your driveshafts are clearing everything.
If driveshaft was knocking wouldn't this also happen when stationary or am I being thick - only noise when travelling and seem worse when going slow
my Ibiza's on coilovers, not massively low but doesn't clunk
I think I have this same issue. Don't know much about this to be honest because I bought the car recently with coilovers already fitted (a month or so ago) Clunking when moving off slowly in 1st gear , seems like it's front left but not sure.
When the car is parked and I grab the wheel with two hands on the top of the tyre and push and pull I swear I can also hear a slight clunk.
Could this be: bushes? droplink? The coilover unit itself?
Getting my cuz to look at it on sunday (he's a mechanic)
Coil slap. My weitec had the same problem, you need some rubber sleves to go over the springs, drop Damian from DPM a pm I think he has a part number now to fix this
