Remote works intermittently
Hi
Having problems with my remote locking
I have an 02 ambiente estate that came with 2 keys.
Just changed both batteries.
Key 1 has always worked fine even after changing the battery.
Key 2 has never worked since I got the car 6 months ago although since changing the battery it does work 1 in ten or so clicks.
Any ideas or do I need to take it to someone with a vag.com? If so any recommend garages in the Exeter area?
Thanks in advance.
Mark.
Hi Mark,
I would think that as it does work every now and then and the other works all the time maybe that the key fob has gone faulty? I have seen this a couple of times.
Mike
I'd agree with Mike. The issue could be mechanical or electrical (switch contact bent so the transmitter never gets power as a rule, bent battery contact, faulty transmitter...)
Is it possible to buy the remote fob part of the key without the metal key part this is the standard non flip key?
Yup check Ebay m8
