Dead vRS tdi
Hi everyone, i seem to have a little problem with a silent engine.
On my way home tonight, the engine just cut out, i dipped the clutch and restarted the engine, about 10secs after that it died again, i did notice the glow light flashed a couple of times. now it wont start at all
ive got it towed home and done the following
checked
cam belt
all fuses
OBD-II scan says no fualts
gone in search on the 109 relay under the dash all i have in there is 460's 449's and 53's
it will crank over but not fire into life, no to keen on taking it to my local skoda they let me down in the past. plus its De-DPF'ed and mapped
Any help please folks ??
martin
Edited by martin1611
Could be the dreaded PD injector!!! If so apparently skoda replace them free now even out of warranty!
would that shut them all down ?
I assume that it has fuel in it and that the gauge isn't giving a false reading? Or maybe the fuel pump is on the blink?
Yes only put 70 in it a few days ago. were is the pump tank or on the end of the cam
From what I've read on here it would basically cut all power to the injectors to stop the short circuit in the faulty one from damaging the ECU. The way I've heard the injector fault described it could well be what you're suffering from.
checked
cam belt
all fuses
martin
with Skoda paying to replace all the injectors faulty or otherwise what have you got to lose by taking the car in to the dealer? they need to be changed before they fail in a dangerous situation. Good luck. tell them VOSA sent you, it seems to help
Edited by Dogsnob
It could be the injectors or one of the fuel pumps. (usually the high pressure one iirc). Does it start it you keep cranking for a while?...and i mean a while?!
Ok ill call them in the morning see what they say. thanks peeps
Yes when an injector fails the car just cuts out mate!!
Best of luck, worth following up on the injector replacement regardless.
Would have expected such a fault to log a code though.
That sounds like the injectors, Im going through the same at the moment. The AA chap didnt get any fault codes, but the Skoda dealer did.
Only one injector down but it shuts the whole thing down like a trip switch.
Im hoping to hear back about mine today, fingers crossed.
Good Luck :)
Update... vw dealer confirms its an injector. they called skoda who will do the work foc. just towed it to horton skoda in Lincoln ..
Are they changing all 4 for you?
