Paint code for vrs caliper green or a match that's as close?
As per title,
I know there copious amounts of threads regarding paint for the calipers but this isn't one of them!
Anyone looked into the paint code if there is one or found a colour to match that's as close as possible?
Si
Edited by sivrs
Go for 2K paint that comes in cans, can get any colour you like from millions of swabs but if you want the paint code i use then ill let you know what it is, providing that you can find the paint!
I'll give it a bash, plenty of paint shops near me :thumbup:
Color is Pantone 348 C - Spring Green
I have just had a two part paint done while I wait in a paint specialist in Northampton. Apparently two part which has a hardener is ok for use on calipers.
http://www.motorpaint.co.uk/
Cheers guys but as per title I'm NOT painting calipers!
It's wheels I'll be painting/getting painted :thumbup:
I think the two pack stuff that i had was a Fiat colour!
That looks pretty close :thumbup:
Well i used a swatch and matched it off the normal fronts!
So it should be pretty good, looks no different from the rears which are still in the original skoda paint!
Dnt keep me in suspense.........what's the code :yes:
Ford Modena green from the mk1/2 escort rs2000 was the nearest I could find off the shelf
I had a ford colour in my mind from somewhere but it was signal green which now I've seen it is way to bright. I'll call in the local paint shop at the weekend when I'm back from work and see what he can do :thumbup:
