window wipers {what next}?
Help required, with ref,to wipers,i have changed the relay ie control unit,changed the stalk,had the motor checked to no avail.Wipers still eratic,stopping in wrong position,and only working after a delay can anyone suggest what might be the problem,at my witts end,with this one, does the brain control the wipers and if so what can be done to rectify this problem also where is the brain on the car.thanks for any help on this one driving me up the wall..... Scoda Octivia 1999 saloon 1.9 TDI...
Edited by doc131246
Have you had the linkage apart to clean the arm pivots where they pass through the bearings?
Had this issue and its commom due to the location of the parts allowing the weather in .My motor was replaced in the end to solve it .
Hi and thanks for your help in this ,have ordered a new motor and linkage weather permitting will attempt to install tomorrow,will keep forum informed....
The park sensor is part of the motor, so a new motor should fix it.
Hi to all got the new motor today and fitted it,Wipers now working a treat,it was the control which is built into the motor which was at fault,thanks to one and all for all your help.... :D
