How much play ....
Should there be in a ko3s turbo shaft??
(spoken to clive about this...)
having found the oil leak on my car which was coming from the turbo cast alloy housing where the exit to the FMIC is,
bought another turbo from a guy breaking a vrs up carlisle felt the shaft of the turbo little bit of play(side to side) nothing back to front but from what i've read KO3&KO3's come with slight play in the shaft from new
is it worth me rebuilding it (kits are 44 quid delivered)
opinions please
I think there will be maybe 1mm movement ish
dont forget there is no oil preasure aroun the shaft so it will be a tad loose but there shouldnt be that much. There will be some tho.
The one I took off that 51 plate car had a very small amount and I am sure that one was the original 112k.
:thumbup:
no just stick it in lol
Is it wet with oil or dry?
If dry - you would expect some play, as the oil has the effect of allowing the shaft to float..
anything you say dear!!! LMAO :p
currently dry as its out of the car waiting to go in
yes i have one off the car at the mo, and there is a little play in the shaft, it should be that way.
Anyone know the part number for the turbo to downpipe gasket ?? and the turbo to manifold gasket?
1J0 253 115 R SEAL TURBO TO ZORST
give me a few more mins to find the other one on ETKA
:thumbup:
06A 253 039 E SEAL MANI TO TURBO
:thumbup:
Right looks like i'm going to have to rebuild the turbo...... oh the joys!
why?
play in the shaft more than 1mm
yep the play was to much and the blades had been hitting the side on the compressor housing!!!
cant believe someone would sell you one like that buddy !!!!
anyways not all bad just do what we suggested and all should be fine ;-)
if not big turbo it is then;-) lol
Spoke to TEG (Stuart Newby) today he says rebuild kit and it will be fine.... even with the 2 thou off the blades it won't make much if any difference to the turbo unless it's all out race/rally car
http://www.tegsport.co.uk/ (friends and customers of mine)
i have to disagree with him as its not just the 2 thou missing its the potential stress damage to the blades wich might cause potential failure once running
imo its not worth the risk!!!
will call you later
