Squeak when turning
I've noticed that recently that when going round a roundabout (started when just turning right but now seems to be left and right) I get a squeaking noise. Now it sounds rotational as when you speed up it the squeak gets quicker.
I've had a quick search and the only thing I could find was to do with brakes. I've checked and the brakes seem find and have loads of life left in them.
Any help would be appreciated.
David
David
David,
I've had this before, especially on a hot day or a long journey, I have found this noise disappers as soon as the brakes are applied, is this the same for you?
Sadly I don't know the cause/cure for this, was a problem for about a month then just went away - it does returns every now and again.
Mike
I've tried applying the brakes but this doesn't seem to stop the noise.
Do you think a wheel bearing could cause this? Just with it only happening when going round bends makes me think otherwise.
David
I had the same problem until I changed to 312mm setup. The brakes might just need a strip down and cleaning and greasing back up. Can sqweek if too much or not enough grease is applied.
HTH.
Andy
