Which engine?
Hi guys
Replacing the engine on my Octavia 1.6 LX '97. Bought a used 1.6 AEE from a Felicia '96 but it appears to be a mismatch with my transmission. Clutch/flywheel housing impossible to bolt on to the Felicia engine.
Apperantly my transmission is the O2K-type (according to the Haynes manual describing the different transmission types).
Can I be sure that my engine is an AEE as the car is from '97 (engine never changed before ;) - and how do I make sure the next engine I buy will fit? I mean, can I only use Octavia engines?? (engine moutings were also a problem, but I guess that could be sorted out)
Thanks in advance
Morten
Edited by Tomba01
You could go BAM which is alot of work but a powerful engine otherwise and AUQ should be a direct fit??
Hi guys
Thanks in advance
Morten
You need to stick to an Octavia 1.6 engine! The clue really is in the title. You have an OCTAVIA but you got a FELICIA engine?????
Engine codes will be indicated on a lug found on the left hand side of the cylinder head.
A BAM (225hp) or AUQ (180hp) would be ridicules as everything would need to be replaced - wiring loom, exhaust, transmission, cooling, ECU etc. etc.
If you want more power you'll have to replace the car-simple!
Steve:)
