Have Skoda put wrong oil in my Fabia VRS
Hewey
Hi All,
Just had my Fabia serviced at a Skoda Main Dealer, noticed they have put on the invoice that they have used Quantum Longlife oil.
I thought it should be Quantum Platinum, can anyone confirm please?
Cheers
I've been asked this by another chap, last week. As far as I know, that oil meets and exceeds the spec of normal 505.01 PD oil, so it should be perfectly OK in your engine.
You can find the specs of the relevant oils here: http://www.thetradepartsspecialists.co.uk/flash/quantum/quantumOils.html
I believe (but don't quote me!) that Skoda have said that the LongLife oil should be OK as it's a superior oil (have a look in the stickied thread for confirmation). However, the Fabia doesn't have the oil condition sensor, so you'd still be on 10k changes.
Guest BigJase88
I dont understand how skoda isnt longlife servicing plan
I had a 52 golf pd130 asz and it was on longlife servicing but a fabia pd130 Asz/blt vrs is on fixed
Beyond me like!!
Edited by BigJase88
It's fine, we put longlife in all PDs now to save on stocking so many different types of oil, we brought the price down in between the two to a middle ground. Saves on space and confusion.
Indeed. My local independent (Midland VW) does the same. The Leon is on normal 10K services, but they use longlife in it, at a reasonable price.
Some are - it depends on whether the car has an oil condition sensor. For example, my parents have an Octavia, one year newer than my Fabia, which is on variable servicing.
I had a 52 golf pd130 asz and it was on longlife servicing but a fabia pd130 Asz/blt vrs is on fixed.
I suppose the question is does the Polo the Fabia is based upon (MK IV?) have a variable servicing option? It would be a bit daft for the Polo to have the sensor and the Fabia not (i.e. no real point spending engineering time to design out something you put in!) ... doesn't mean it's not the case though! :blush::giggle:
Guest BigJase88
Tbh i dont think a golf tdi on a 52 plate has an oil condition sensor? But it was longlife servicing
Also i had a lupo gti that was on longlife servicing and it was an 02 plate
I did however change oil on both cars at 8-10k miles as 20k is stupid
