3 BEEPS NO WARNING LIGHTS FABIA VRS
Hi, Got a 2005 Fabia VRS (96,000 miles) - regularly serviced. Recently had 3 longish beeps on 2 occasions when accelerating away. Most recent was yesterday when accelerating in 2nd gear - definiteley no warning lights showing at same time and car driving fine - any ideas please?
Bob
Welcome to Briskoda, not sure on your query but sore someone will be able to help.
Hi and welcome aboard.
I'd get it plugged in and get the fault codes read.
Any idea where the beeps where coming from? Dash panel? A speaker? All speakers?
Hi there was a fault with the abs control units on these fabias and the only way to fix it was to replace the control unit which can be replaced without removing the pump. It does need interogating to confirm this as the coolant bottle low level sensor is also very common but normally the light would flash too. Hope this is helpful
Neil
www.Sultas.co.uk
