rally 100w's ok with xenon plastic lens?
hi, just wondering if its ok to use 100w main beam bulbs with these poly-whats- it plastic lens's. i've just fitted them and they seem to generate quite a bit of heat, just dont want the lens melting.
any advice welcome :(
I believe Roo has some better bulbs in his fabia vRS with no problems, wether they are 100w though I can't say for sure but they are alot brighter.
Sorry for being dumb here (hey you should be used to it by now :rofl: ) but are the Xenons only for dipped main beam then and you still have a separate 'normal' bulb for high beam then?
Yep - not bi-xenons, so dipped is xenon and the main beam is an H7 halogen bulb :D
Chris
yep :)
Suppose I'd better get those bulbs changed then :)
Kinda used to having decent bulbs for dipped & undipped now. The rover has H4 fitting and I bought some Philips jobbies for that. Good investment, especially when taking into account how much crud you get on them during a normal commute (near-50 miles).
Thanks for feedback :thumbup: - little wiser again now :D
Yep - not bi-xenons' date=' so dipped is xenon and the main beam is an H7 halogen bulb :D
Chris[/quote']
actually there H1 bulbs though powerbulbs originally sent me H4 as suitable for the octavia through there online car configurator :rolleyes: inever bothered checking :o
Fair enough :) Does the manual say H7, or have I completely imagined it? :D
Chris
The manual is WRONG!
I spent
Chris[/quote']
On the Fabia -
Dipped Beam is H7.
Main Beam and front Fog Lamps are H3.
We always seem to be getting confused about which ones to use :rofl:
H3s for main beam & fogs - noted :D
IIRC, Jon (taviars) spent ages taking the light apart on his SDI octy with xenons (didn't know you could get them as an option :confused: ) to fit some uber bright main beam bulbs without any trouble. Still running them and has now covered 50k or so miles...
On the Fabia -
Dipped Beam is H7.
That's on the non-xenon ones ;) The manual says H7 for main beam on the xenon ones, whereas it seems it should be H1! :D
Chris
As you've ordered xenons, you'll want H1's for main beam and H3 for fogs ;) Is anyone else getting confused? :rofl:
Chris
Dunno yet :confused: :confused:
:rofl: - I will probably wait till I take delivery first anyway, I've already got to fit the tax disc holder, the Furby beanies I bought ;) and hopefully the vRS key ring(s).
:rofl:
LOL
I now feel really bad about all this bulb mallarky. After lots of cursing (see here) and asking Jon to modify his post here, I think Colin is right with H1 :rofl:
I can't figure out where I got H7 from, but looking at picks of H7 bulbs, IIRC, the ones in my ex-xenoned-fuby looked different :confused:
:o :O :o :O :o
Could I have a confirmation about what a Fab vRS 2005 WITH Xenons needs for it's main (undipped) and fogs please? I believe it's H1 main, H3 fogs based on a previous post ?
Yours confusedly ;)
Fogs are definitely H3 ;)
Chris
Tnx ;) Fogs H3, what about the mains ;) H1 based on a prev post ?
