Eggy smell and loss of power
Driving home yesterday and the car started to lose power, also getting back eggy smell and the exhaust sounds like it is rattling. Any ideas
Coil pack or the Cat?
A eggy smell is usually the cat, or could be middle or back box baffles gone making a blockage.
hope not there stainless steel though it mayt be the Cat, if thats the case is there any secondary damage to look out for. Had a quote for £150 for a replacment for Catman is that a decent price?
It makes me think "cat" too.
The alternative is that, if you'd just filled up from near empty, that you got into a batch of high sulphur fuel. In that event, fill up somewhere else as soon s you can get 3 or 4 gallons in, then run til near empty and fill up again.
As to secondary damage, it's unlikely. Don't stress it until you see if the symptoms sort themselves out with a new cat (or fuel as para (2)).
Funny you should say fuel as my wife put £20 worth of Sain**bur** cheap unleaded in a few days ago, despite my implicit instruction to always run it on Shell Optimax. I have just put £35 quids worth of decent fuel in and some fuel cleaner was unsure weather to run it or not.
Just had it check by 2 garages and they dont think its the Cat, seem to think it could be electrical.
If it's only part-full, fill right up with decent fuel (BP, Esso or Shell), and I think you'll see an improvement in about 20 miles.
The "rattling" noise may be pinking, aka pre-ignition, caused by the use of low octane fuel. Has the car been mapped on 97 octane or something?
Possible result, called SKoda and they have taken in for a diagnostic test as their was a recall on my car for faulty coil pack(s). Hopefully this is the fault and they will do it under warranty.
Failing that they should find the fault so at least i know whats wrong.
If you need a cat, I have one taken from my old Mk1 Octy vRS, when I fitted a full Blueflame turbo back system. Taken off at 25K and in perfect condition.
If you need it, please give me a pm, but if it is the cat and Skoda want to replace it, just make sure your sitting down when they give you the exchange price.
If it is the CAT i will definetly have your off you, Skoda want 1k for one. Could get a sports cat for £500, will defo contact you if it is.
Here's hoping its the coil pack and its done under warranty
Not much help, but I tend to suffer these symptoms after a large cheese and onion omlette :(
:)))) is that the eggy smell or the lack of acceleration !!
There's always one!!
RESULT....was the coil pack and the dealer has replaced them all under the recaal, and is even washing the car as i speak.
Thanks for the advice, would have never have known to contact the dealer and metnion this
It's usually you :giggle:
