WTF? is ABS, EDL, ASR, ESP, HHC....etc?
Decided to write a guide to all the confusing acronyms that are used by Skoda. This info is from their manuals, sales litrature etc, but put into plainer english!
This will cover all Roomster models so several versions of the same thing may be out there due to the time period I am covering.
ABS = Anti-lock Braking System
This uses sensors in each wheel hub carrier and a magnetic reluctor ring on the hub to sense the speed of the wheels. If during braking one or more wheels are going slower than the others, indicating that those wheel(s) have slowed their rotational speed (loss of traction/skidding) and could lock, then the brake(s) on those wheel(s) are released until those wheel speeds match the others.
Works on all wheels during braking only, to prevent wheel(s) locking and skidding. This is "ON" all the time and cannot be deactivated or switched off, unless the main fuse is pulled. The warning lamp on the dash will flicker on and off when the system has been activated, and you will feel a "pulsing" (quite sudden and heavy) through the brake pedal, as if it is trying to push back into your foot. If the warning lamp is permenatly illuminated, this indicateds a problem/fault with the ABS system, and that the ABS system is now deactivated to protect itself. In this case braking is "Old School" without ABS!
MSR = Mechanical (or Motor) Slip Regulation
This uses the engine's ECU to reduce the torque supplied to the drive wheels to reduce wheel spin, eg it reduces the power output (via the ignition timing/sparks/fuel, etc) of the engine to prevent further wheel spin, mainly when changing down gears on a smooth or slippery surfce. It has also been reported that whilst under full power (from standstill) coming out of a junction it has suddenly cut power to reduce wheel slippage, thus leaving you halfway across the junction now under reduced power! This function can not be deactivated or switched off, nor does it flicker any lights on the dash when it has been activated!
EDL = Electronic Differential Lock
This requires the car to have ABS to operate.
This will use the ABS sensors on the main drive axle (front) to sense if one of the drive wheels is rotating faster than the other. It will then brake that drive wheel until both the drive wheels are at the same speed. This works then the accelerator is being used and the brakes are not. Effectively this works as an LSD and is also known as "Fiddle Brakes" and has been used in F1, with manual versions used in tractors, hill climb racing, and 4x4 trail racing. This is always "ON" and cannot be deactivated unless the main fuse for the ABS unit is pulled. When this is working "Active" there is no light that flashes/flickers etc to tell you it is working!
ASR = Anti Slip Regulation
This requires the car to have EDL, MSR, & ABS to operate. This feature gives you a nice button on the dash with ASR (TCS on other VAG cars) on it and maybe a "skid" symbol.
This will use the ABS sensors to sense if the driven wheels (front on FWD) are rotating faster than the non-driven rear wheels . It will then brake the drive wheels (this system only brakes the drive wheels) until both the drive wheels are at the same speed as the rear non driven wheels. It can also use the MSR function to help reduce the power to the drive wheels if needed. This works then the accelerator is being used and the brakes are not. There will be a switch on the dash to deactivate this. The system is "ON" all the time. Pressing the switch deactivates the function and illuminates the respective warning lamp on the dash. If the ignition is then switched "OFF" and then back "ON", the ASR resets to default "ON" again! When this is working "Active" the warning lamp on the dash flashes on and off, indicating that it is currently sorting out the lack of traction!!
ESP = Electronic Stability Program (In this case NOT Extra Sensory Perception.. :giggle: )
This requires the car to have ASR (EDL, MSR & ABS) to operate. This feature gives you a nice button on the dash with ESP on it and maybe a "skid" symbol. This superceds/replaces the ASR (or TSC) button (you do not get both buttons)!
This system uses a gyro sensor (lateral acceleration and yaw) fitted either under one of the front seats or behind the lower central dash (usually on the exhaust tunnel) to sense cornering, g-force, etc, etc,. It will also use information from the ABS system, power steering wheel sensor, engine ECU, etc to work out what the car is doing and the current inputs by the driver. It then compares these actual readings against predetermined values and then according to the situation it will either brake individual wheel(s)(this system works on all 4 wheels), and/or reduce engine output. All to reduce the amount of under or over steer and keep the car on the course steered by the driver! The system is "ON" all the time. Pressing the switch deactivates the function and illuminates the respective warning lamp on the dash. If the ignition is then switched "OFF" and then back "ON", the ESP resets to default "ON" again! When this is working "Active" the warning lamp on the dash flashes on and off, indicating that it is currently sorting out the lack of traction and stability!!
HBA = Hydraulic Brake Assist
This increses the optimal build up of brake power, thus making sure that the whole of the braking system potential is used up to shorten the braking distance.
MBA = Mechanical Brake Assist
This requires the car to have a dual rate brake servo.
This muliplies the effort that you exert on the brake pedal to in turn put more force on the brakefluid to help stop the car quicker in an emergency situation. This is allways "ON" and cannot be deactivated.
TPM = Tyre Pressure Monitor
There are two versions made in the VAG group. At the time of writing most VAG cars have the "Indirect" system, only top end models have the "Direct" versions.
"Direct" = This uses battery (or battery less self powered) sensors built into the inside of valves on each wheel to relay the pressure signal to a receiver (either a single central one or one in each wheel arch). This system will tell you the actual pressures of the tyres and will warn of a flat tyre, all using the Maxi-dot display on the dash.
"Indirect" = This requires the use of the cars ABS sensors to measure the roational speed. If a tyre deflates is diameter will reduce, thus the rotational speed will increase! This then idicates that the tyre is deflated! This system cannot tell you the actual tyre pressures, but will iluminate a warning lamp on the dash, or the maxi-dot display, when it detects a flat tyre.
Additional acronyms from 2011 onwards:
DRVBB = Dual Rate Vacuum Brake Boosters
This requires the car to have a dual rate brake servo & ABS, as it is part of it (you get this as standard with ABS)
This is a newer version of MBA.
EBC = Electronic Brake Control
This requires the car to have ABS, as it is part of it (you get this as standard with ABS)
This is the newer version of the earlier MSR system and still uses the engines ECU to regulate the amount of torque transmitted to the drive wheels.
HHC = Hill Hold Control
This requires the car to have ABS & ESP to operate.
This uses the ESP gyros' to sense that the car is on a slope, it then uses the cars ABS sensors to lock the brakes and stop "roll back" (accidental reversing) when moving off from a standstill on a slope.
ABS + (Plus) = ABS including TPM
ESP + (Plus) = ESP including HHC & TPM
Roomster spec combination list up to 2011
1. ABS
2. ABS & TPM
3. ABS & ESP (ESP includes ASR, EDL, MSR & MBA)
4. ABS & ESP & TPM
Roomster spec combination list from 2011
1. ABS (ABS includes EBC & DRVBB)
2. ABS Plus (Plus includes TPM)
3. ABS & ESP (ESP includes ASR, EDL & HBA)
4. ABS & ESP & TPM
5. ABS & ESP Plus (Plus includes TPM & HHC)
EDIT this is a work in progress and stuff is being added as and when I get the time!!!!
  • 10 months later...
Thank you for this fantastic post!
I just found this forum post via Google, as I searched for 'abs esp asr'.. as I had no idea what those meant :)
I see the post is quite old now, but no one ever responded... I just had to fix this injustice, and made forum account just to post one big THANK YOU for your explanations.
Thank you very much, you've made it all clear for me now :)
Many THANKS!!!
I do these so they are a permenate referrence guide for all to use............I'm glad it is helpfull!!
B)
Nice post.
Hope you do not mind, but i am going to put a link to it if the Fabia 2 section.
cheers
george
Nice post.
cheers
george
You can do........
there should also be a copy of this in the Fabia tech section..........but things get a bit lost/buried there......
found it 1/2 way down page 2..
http://www.briskoda.net/forums/topic/214776-wtf-is-abs-edl-asr-esp-hhcetc/
so link that one instead????
  • 3 years later...
This is really useful to know what the features do. I have never had to brake hard enough to activate ABS during three years of ownership. It is reassuring to know that it is there when I need it
