Help
I hope you can help? My engine light keeps coming on. The diagnostics say that the engine mixture is too lean, injectors are blocked and leakage. I have had a servo pipe replaced and an air mass sensor replaced. When the engine light is off, the tick over (when I start up) is high. When the engine light comes back on it goes back to normal. Any help would be appreciated.
Have you run some injector cleaner through it?
Fitted a new air cleaner element?
Alternatively, you could hit it with your swords? ;)
Hi Ken swords would solve the problem, lol. I will try some redex in it and see a specialist tomorrow. Good choice of literature.
Redex is rubbish. Get some Forte injector cleaner it's much better.
