vrs tsi oil type
Got an amber oil can flash on the maxidot today. Guess it is low oil warning so need to buy a top up bottle. What's the stuff in there so I know what to get please ! And I mean make formula weight and grade !
It will be VAG spec 504.00[petrol] 507.00[diesel] 5w/30 fully synthetic.
Cheers, any idea what make and brand it is ? Castrol edge, Mobil 1 etc ?
Flexible servicing QG1:- VW 504 00
Fixed servicing QG2:- VW 502 00
Quoted from the Handbook, page 210
Hope this Helps
I have used Castrol Edge to 504 spec, get it cheap in ASDA.
I'm currently using 502 spec Quantum oil (VW brand) from a VW parts shop.
I'm on fixed servicing.
As above - Castrol Edge 5W/40. £35.00 From Asda if memory serves me.
VW Spec oil. 5w 30 is fine for top ups but you would be best to Use Catrol Edge or similar 5 w 40 as I posted before thats what the dealer uses in vRS a little thicker oil I believe.
I've it's topped mine up with some castrol edge
Hi, most 502 grade oils are 5-40 and the majority of 504 specs are 5-30, as quite a few cars are now suffering from excessive oil consumption I suggest going to fixed service interval and using the 502 spec oil with a 5-40 grade and see if you can avoid this problem.
