HELP!
Hello! I have just registered on this Skoda forum because last night my driver's door would not lock...I have never had the problem before and it was fine earlier in the day. I own a S Reg Skoda Felicia and it doesn't have central locking. I put the key in the lock and turned it but instead of locking the car it just continued turning round and would not do anything. I then attempted to push the button inside the door down but this would not press down either. Does anybody have any ideas?? Maybe the lock is just broken and I will have to take it to be fixed!! :(
Hi there,
It sounds like the lock barrel end spindle has broken.
When you put the key in the lock there is like a spindle that extends from the key barrel to the door lock, They snap off after a period of time (Common fault)
Easy to replace lock, you will need a star driver to release the screw that holds the barrel in the door.
Hope that make sense!
Parts available from main dealer or scrappy or try vwsalvage.co.uk
Hello and Welcome to Briskoda.
Are you cute?
welcome to briskoda
Welcome to Briskoda!
edit - It may be worth posting your issue in this forum >clicky< somebody more technically minded may be able to help you in there...
Hi and welcome aboard.
