312mm Calipers And 256mm Rear Carriers And Callipers - B5.5 4motion Passat 2.8 - 5 x 112 PCD - £25 Posted Each
Hi
I have a set of 312mm front brakes calipers and 256mm rear calipers from a 4motion vw passat
Bought as a project to upgrade my standard brakes on my ibiza
Am reverting back to standard on the ibiza so dont need the brakes
All bolts, pins, pipes included
They are slightly rusty
Fronts need new seals, backs look ok
Photos -
Really dont want to post due to weight but can if needed
Looking for £100
Pm or email - [email protected]
Tom
Would be interested in them, just too far to collect ;(
Did you get a spacer kit for the fitting of 4mo rear brakes to a 2wd car? :)
Hi
No didnt get a spacer kit for fitting the rears - what would be required?
Tom
Even with the spacer kit they still don't fit 100% you need 2wd rear carriers if they are being fitted to a 2WD car.
Passat also a different platform, but I think if you swap them side to side they might work.
Fit a 4x4 Octavia MK1 no problems though.
Good point! Didnt think of this, only want the rears.
Due to them being 5 x 112 PCB and more better for 4wd`s - il split if needed - offers invited
Tom
Hiya pal . One question- Are they 312 as the 4Motion b5 passat did not have them as standard, they only fitted them to select b5.5 passats with v5 engine and auto gearbox and FWD 2.5 tdi + a few quattro's with bigger engines...
is there any part nos on the carriers or names . im really after the 312mm carriers if poss pm me please
cheers
ant
Hi - They are of a B5.5 Passat 4Motion 2.8 V6
Some numbers
312mm Front
Carriers
451 - 5440
Calipers
57 257/0 8852VL
57 330/0 8963VL
256mm Rears
Carriers
256 6840/1 CN6-A259
Caliper
542
If that makes any sense to anybody, if not il start scratching to try and find codes
Tom
i will double check and get back to ya
ant
think its just some tdi 4mo's that didnt necessarily have them, a v6 4mo B5.5 should be sound, good price btw, if you were closer i'd have them no worries
payment sent for 312mm carriers
cheers
ant
312mm Carriers SOLD
312 callipers £30 + postage
256 calipers and carriers £30 + postage
Tom
312mm Front calipers - £30 posted
256mm Rear Calipers - £30 Posted
Or make an offer
Tom
312mm front calipers £25 posted
256mm rear calipers £25 posted
Tom
Pcb or pcd fella? ;)
5x112 pcd
