Load Signal Wire
I've been reading some posts about checking the load signal wire for problems with alternator/battery charging etc. I'm not aware of an issue on my car, but I would like to be pro-active and check as I did have the issue with the starter motor cable breaking, so I think it's better to be safe than sorry.
Does anyone have any pics/guides showing where the cable is on the Fabia?
Many thanks!
Under the starter motor, the bracket that holds the connector is bolted to the lower starter motor bolt.
