fault code 16686
have error code 16686 changed spark plug changed coil checked cylinder pressure still no change any ideas
Not a clue, sorry but welcome along anyhow.
If you stick your question up in the Fabia section you're pretty sure to get a response :thumbup:
How about a clue, what vehicle, what engine, what year?
sorry fabia 1.2cc 2005 52000 miles
So it's a 1.2L (or 1200cc)
More than likely an injector over fuelling, you can check this by moving the injector and see if the misfire moves..
Failing that you say you have checked cylinder pressure, I assume you mean a compression test? If that's ok you then need to do a cylinder leakage test, there is a possible issue with worn valve guides leading to odd shaped valve seats.
Hi and welcome aboard.
