HELP needed car does not boost in 1st or 2nd gears
Hi guys, my car which is a 2005 skoda fabia vrs i have had it for a few months now just got a fault today car is not boosting in 1st or 2nd gear goes to 3k revs makes a rattling noise in 3rd onwards goes like stink got no engine management light on etc car as had a custom code remap done on it before i brought it 6 months ago car feels like its struggling like it goes in limp mode just does it one off what can it be??
Does the performance reset back to normal when you turn off and turn on the ignition again? if so it could be the sticking vanes on the turbo causing an overboost condition.
My mate nick had this. New turbo was cure
Hi guys, does it one off when its fully warm only in 1st and 2nd gear for instance if 20mins of driving and i want to move it quick in 1st it would struggle then when i put it in 3rd power comes back most the time its a1 just 1 off it does it the power is there all the time when it struggles it does slightly smoke
Is running perfect today guys took it to a garage aswell and he said it could be a boost pipe gonna get it booked in on monday will keep you guys updated, cheers
Doesn't sound like overboost - it would never go off like a rocket then. I would suspect the MAF breaking down - unable to read/fathom the airflow until faster speeds, i.e 3rd gear and above. :) Try unplugging MAF next time it does this and see if 1st & 2nd performance improves.
turbo pipe under the car near the front driver side wheel was slightly coming off lucky so sorted it now the car is like a rocket again touch wood thanks for your time and thanks much appericated guys own you 1
