Intermittent power loss VRS
Hi all I have read lots of posts on the problem I have with my 2007 VRS petrol-when driving on the motorway in 6th doing 60mph sometimes not all the time the turbo doesn't kick in until about 3000-3500,it also does this on some b roads as well.4th or 5th,if I drive it hard from the start then all is well turbo kicking in about 1600-
All the other posts I have read never give the outcome to what the fix was ,could this be a sign of a worn DV?? I do not hear any hissing noise when the turbo is spinning.
Please can someone shed some light on this as its doing my head in.
Thanks All
Potentially could be a split DV. Is your car remapped?
No its standard,if the DV is slipt or is perished could it be intermittent ?
40 quid for a new dv so its a no brainer really - change this out and see if it still has a problem.
Anyone know the part number for a DV for 2007 VRS would mine be a TSI or a TFSI?
is this the correct part number for my car 06H145710D ?
TFSI and yep correct number.
If the dv is split you usually get a bit of boost then it ball escapes and seems flat in acceleration ,like a FSI rather than TFSI . The new ones have been revised to a piston type so you will have no more issues :yes:
