Anyone had any bother with their remap?
Hi All
Had car remapped about a month ago (200 bhp) had it taken off for a few days while it was in the dealership and had it put back on (flashed back) about a week ago
Iv having a few issues with it though, the car badly kangaroo's under heavy acceleration, the car suffers with a knackered DMF but when the car jumps its not making the clutch slip so that suggests to me that it lays with the power delivery from the engine and nothing to do with the drive train. Its also unpredictable, some times it does it and sometimes it doesnt :S so that leads me to think electrical fault? if it was a mechanical fault then it would surly do it every time?
Anyone experienced the same thing?
Hi All
Take it back to your mapper. May be a software issue, but highly unlikely. Could be a faulty MAF or sensor
Edited by sdmegawuk
Wouldt this be flagged up on a vagcom scan though? it was scanned before the map was put on so make sure it would conflict with anything else
What map
Not always. try unplugging the MAF sensor & see if it improves. If it does thats your problem.
What map
Im not sure what you mean?
thanks ill try taking the MAF off
Which company did your remap?
Ah right, Big Fish Tuning, i dont think there is anything wrong with the software as he has remapped other BMN's and iv heard nothing bad about the service
If it didn't do it before the map and now does take it back to your tuner. Does it have the same problem on the standard map?
BMN PD170 is a bitch of an engine to map properly. Its well known to "Stutter" and "Kangaroo"
mine used to kanagaroo in 1st and 2nd and then stutter in 5th and 6th
I got rid of mine! How:
Low down Kangarooing was solved by a map update by Custom Code, 5th and 6th stutter was resolved by EGR Delete.
Standard PD170's with OEM map have been known to also suffer this problem, its just that the Remap highlights it more
No it did not kangaroo when it had the standard map but with him mapping so many other 170's and having no issues i just thought the remap has highlighted a problem within the engine
Ill give him a ring and see what he says, only annoying thing is like i say it does not do it 100% of the time, maybe about 80% of the time so knowing my luck if i take him out in it, it will perform fine! :dull:
No one has said it yet im shocked .....Try Ben.
Sounds like common DPF related problems on the PD engine, have you had the injectors changed yet too??
My 2008 Leon FR TDI did this for a while, usually during a DPF Re-gen but not always, would almost feel like it was holding back, then it would suddenly go and cut again....
It's since been to Seat and had all new injectors and so far so good!
Cant be DPF Related because mine also did it and ive not had a DPF for about 2 years.
Its the mapping, There's a common fault on the engine that gets highlighted by the mapping, some of the settings need to be changed (i dont know what needs changing)
Shark Performance are aware of the problem, Mikko maps around it now
Does it do it with the map off? A sure way to tell if its the cause. If it does then keep it off and get a warrenty job at the Skoda dealer, that is if you have any.
iv messaged the bloke who mapped it for me and im waiting for him to get back to me.
by the sounds of it from your experiences it could be the software :dull:
It's VERY likely the software, possibly also a combination of software + failing turbo. Guessing it happens when you put your foot down after a period of driving steadily?
This was nearly two months ago, did you get it sorted? Was it the map?
What miles is on ur car? Did u say it's used for a taxi?
