Flywheel fitting help asap
Just about to fit my flywheel is there a correct way or aslong as the bolt holes aslign am i ok to go go correctly torque bolts? Ie does timing mark have to be in certain position? Cheers
timing mark should be visable through gearbox hole with engine at tdc, if you fit it wrong maybe a risk in time of a cambelt change being messed up due to someone using the flywheel mark and not realising its not in right place.
pretty much everyone uses the timing mark on the bottom pully because its too much hassle to use the timeing mark on the flywheel so aslong as the bolts line up its fine its the way ive always done it its the way eveyone i know does it :)
agreed but its used as a double check
