17x8 et38 offset wheels...
Any thoughts from the wheel gurus?
235x45 rubber
I think they will but it may be a costly experiment?!
225 45 would be a closer tyre.. 235's are more than 2% different to the OE boots but you'd probable get away with it.
Rims will give more inner clearance but push out about 19mm vs OE, should be ok - oobsters vmr's are 8.5 et45 so the outer edge is in a similar position and he has no rubbing.
:wonder:
