FL Octy - Aftermarket HID Upgrade FAIL!
I still hav'nt fitted the things yet - the clips were crap and I can't find any alternatives so I'm faced with cutting my originals to allow the bulbs to fit!
  • Replies 57
  • Views 7.2k
  • As has been suggested earlier this thread is not about legality but I would suggest you look at the actual wording in the 2012 MOT guidance which states... Vehicles equipped with High Intensity Disch
  • How on Earth are the Police going to spot cars with projector headlamps and a Xenon upgrade (that give the exact same beam pattern) as opposed to OEM HID ? They would have to have check points pullin
  • Well one of the issues is almost certainly the fact that you have a "Canbus" kit. This uses a large resistor to "load" the system to stop the bulb out warning being an issue. There is considerable evi
It is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
The following is the legal rationale:
The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above."
k
k
Thank god you mentioned this, nobody else knew anything about these rules :dull::x
Edited by xpower
:D
Now THAT's good quality sarcasm.......
k
yeah petetdi....having been an automotive lighting engineer for the last 20 years I hear what youre saying....but aint it fun to tinker!!!!
and if you think putting an aftermarket kit into your headlamp is criminal, have a look at my installation of genuine Hella PES units with OE ballasts....oh shucks...slap my wrists, lock me up and throw away the key!!! :hi:
.....http://sdrv.ms/KU45iN
After trading some mails with the user ALAM, here´s the conclusion of the shaking
Sent 25 February 2012 - 16:31
Hello
I finally found out the shaking problem, its the three ball joints holding the projector. The ball joint connected to the leveling motor has some movement, which is needed to be tightened. Any way to tighten up the ball joints? Em planning to put some silicon sealant on the ball joints. When the sealant dries up it form a rubber type material, which will make joints tight. What do you suggest....
Regards
Alam
The bulb holders will not help.
There is play in the projector lamp carrier frame to levelling motor/adjuster posts....tis one of those things im afraid!
Hello
Regards
Alam
Hey Alberg....yeah thats the issue (as I mentioned above) but its not something that you can easily fix! basically the carrier is held in the headlamp by 2 adjusters (one being the levelling motor) and whats called a FPP (fixed point post).
The cups that hold the ends of the balls (on the end of the posts) are pushed into place and require movement so that the headlamp can be adjusted.
If you wanted to go to the extreme (and this would only work with Halogen lamps) you could bond or glue one of the top adjuster, by doing this the lamp would be fixed but you would probably not want to use that adjuster motor!!
most lamps exibit this flicker and projectors are heavy units which dont exactly help!
:D
I'm going to sleep so much better knowing that now. I also wondered why nobody ever mentioned all that before!!!
