Activation
Getting a few features activated Friday morning :-) blip when locking and single click unlock. Anything else I should look at getting? I got oil temp and stuff ale ready on maxi dot
I like the automatic door locking when the car goes over a certain speed.
Sounds cool I'll have that
And also lane change (I think it is called) set from 3 blinks to 5. Really wanna do that to mine.
Lane change awesome it's on the list
That's the 'comfort indicators' IIRC.
Not sure about a Fabia but some of the popular changes on the other models are:
alarm chirps
selective unlocking
anti hi-jack
seat belt warnings dissabled
staging (needle sweep on ignition on)
large digital MPH display
CH / LH lights
Assuming this is for a MKII as your sidebar says 2006 vRS.
Yea sorry mk 2 - got needle sweep want mph maxidot activating.
How do you activate these things ??
VCDS :thumbup:
Would skoda do this for me, i want the sweeping speedo indicator
You can ask, depending on how good they are they will either:
1/ do them FOC
2/ do them for an hourly rate (15 - 30 mins maximum)
3/ tell you they cannot be done on your car (they can)
VCDS is much more user freindly and usually much cheaper than getting your local dealer to do them.
Mine are getting done FOC I just rang after sales. Also going to discuss Bluetooth installation
I think they are called "Convenience" signals... Bloody inconvenient to my learners. Explain exactly how they work and advise them to leave the signal alone if they accidentally apply it yet they still try turning the signal off. Turn left, turn right, turn left, turn right... Leave the flaming stalk alone!!!
LOL!
1/ do them FOC
I had the 3 rd response told me I did not have maxi dot ? And I have as its standard fit with Amundsen sat nav , IDIOTS!,,,
Ok well we ran into problems yesterday, they couldn't find the mph display to activate which was annoying. They did say however if I could fin any more information on this, it's name and where it's found in the system they will do it for me. Hellp :)
On mine I changed the country from UK to Australia and the option becomes available,
Have you done a search?
I have posted this numerous times before, however I use VCDS and dealers do not so the procedure will be different.
How do I do that mate?
With VCDS it is done as follows:
You can remove the small KPH display and replace it with a large MPH display:
However you will need both maxidot fitted to the car (as shown above) and someone with VCDS to change the country setting to Australia:
To set the country to Australia:
To change the country go to 17- Instruments and click on "Coding - 07"
Then click on "Long Coding Helper"
Finally under Bit 4 select "70 Country: Australia (AUS)"
Exit this screen and you will return to the previous screen (with the current & new coding displayed) you see that the long coding has changed, click on "Do it!" all will then be saved.
Once you have made the changes with VCDS you then need to go into the maxi-dot menu:
SETTINGS
Units,
"Consu/distance" change this back to mpg (GB), mi (as it defaults to 1/100km, km),
then
SETTINGS
"MFD data" and make sure the box for Digit.speed is ticked
You can also remove the KPH display and replace it with the outside temperature:
SETTINGS
and unticked the "ALT.speed dis." box (this will remove the KPH speed and replace it with the outside temp display)
I need someone near me with vcds!
change your xds settings from thandard setting zero to setting 2( strong ). massive imporovement in traction. i did a thread on it a few weeks back
Sy have you any light to cast on my other post entitled "problem" I can't figure it out.
Me too...!!!
Me too...!!!
Folkestone not too far??
Nope... Do u know someone and if so how much would cost to change some stuff..? Cheers. Matty
