The Norwegian vRS "Low Clearance"
Stamsaas
How did you code the 'blinkers' to light constantly?
With VCDS. Controller 09 (Central Electronics), Byte 7. I think it's an 8bit value, so range is 0-255 to set the brightness. Set it low though. Like 50 or lower.
It is US parking light yes, I have preFL with FL front so I can still turn on US park on the FL front. On the FL US park cant be turned on via VCDS. I adjusted it by % in VCDS, so I had 17% with is about parkinglight light, when the indicators are flashing they are flashing 4 times as bright so they are clearly viseble :)
Some more photos from the painting;
Universal use of carlift
Lambo <3
Masking of
And on car
And the 1.place, and the icecream to celibrate :D
And some of the other Skodas on the meeting
  • Like 2
Sent from my iPad using Tapatalk HD
Stamsaas just the man.
Cars lookin awesome as usual.
9.5's on the front did you encounter any issues? I'm only looking at 9.5x18's all round to keep tyre costs down :)
I assume running 19's you'd know what problems I'd come across if any.
Keep up the good work
Aknedude: First I have to deside what I do With them. Nine sets of Wheels should have been enough :p
giggs: Thanks! :)
SNH: Thanks :) 9,5 in front is a pain. I have never driven With it but I tested one 9,5x19 front, and it was totaly useless. 45degress turn on the steeringwheel, and the tyre was stuck in the Arch.. And mine is rolled slightly.. 18s will help you a litle, but you must have a ****load of stretch to pull it of, if you gonna drive low :) and low you must be, or it will look like **** :p
Then it was time to do a Complete detailing again
did not take so many pics, but here is one while woring
And finish, Skoda Raceblue vs matt Lamborghini Ballonwhite <3
Going to a stance show next weekend, so now i am ready ;)
  • Like 4
And for those of you that say lowered car is useless, look here now ;)
Tok a ride the other day and was lucky to find not one, but two sets of wheels to my track car, in total of 8 rims with tires. Glad I had a STV! :D
No rubbing on the way home! ;)
