What hids do i get.
I got the hids direct kit ( but the older no twin relay )
I love them :)
In the standard lights, none.
Get the OEM ones.
Ideally you want the whole OEM setup, you could try getting the OEM Xenon light units and fitting an aftermarket kit but whether it will get through an MOT or not is anyones guess.
Xenons in the standard headlights are awful, all they do is blind everybody coming other way
As said above try and get standard setup
I checked the mot book today the rules say if washers and self levelling are fitted they have to function it doesn't mention in reason for rejection columb hid lights fitted with out washers etc is a reason to fail
So as a mot tester I would pass and advise if i saw a kit with no washers etc
http://www.motuk.co.uk/manual_170.htm. Have a look
What about an incorrect beam pattern?
Well that's defo a fail but can u not get hid kits that project the correct pattern ?
Not kits, no. But you can get headlights with projectors. After market HIDs in standard reflector headlights will produce an incorrect beam pattern, with massive scatter.
See I dident know as the BMW I moted today had projectors with aftermarket hid lights
With projectors, the beam pattern is fine, but after market HID kits aren't designed with reflectors in mind.
My beam pattern was fine with Hids in it was the scatter that was the problem, it just blinds everybody coming other way
I fitted a set they were in 2 days and i took them out
As meg said, it isn't so much the beam pattern that's wrong. The pattern can be perfect, but there will still be excess light scattered, simply due to the fact the lamp is 5 or more times brighter than a halogen one (especially the 55w kit HIDs4u sell. That's just stupidly bright). A standard halogen bulb has scatter too, only it is nowhere near as bright, so isn't a major problem.
In a projector lamp, all the light has to go through the projector lens, so there is no scatter and a perfect cutoff.
Putting discharge lights in a reflector that isn't designed for them is stupid, and is one of the things that really p*sses me, and everyone else off on the road.
Edited by rk696
These are a proper menace when not fitted correctly. Dangerous IMO.
I had a feeling the thread would go this route :giggle:
lol, they always do don't they?
Yarp :rofl:
Hid threads end up locked dont they
Some like
Some dont
Some care
Some dont
If you want them , get them
Ive never had mot issues
If the become illegal then hey-ho
Like ive said before , speedings illegal and that wont ever stop
Im sure people on this forum my sneak over the limit a few mph or more lol
Aslong as there are cars there will be things you can do that you shouldnt
Theres loads of hid kits around brizzle, i rarely get grumpy folk flash,
Your best plan bud, deside if you want some and then get them, or dont
( hids direct would be the ones imo )
Goodluck
Of course everyone speeds. However dazzling other road users with HID bulbs which were never designed for the units is a different matter entirely.
Both could be looked as dangerous tho, people wont stop using them aslong as they are being made
Ive only actually been flasehed once or twice, since dropping them down ive had no trouble
I can also see very well at night lol
I until i get a suv with factory xenons come over a hump or something of course,
Maybe hid threads should also be banned as it provoke strong opinions which tbh start people getting ****ed off
Like i said, if people want them then get them, if you dont want them..... Dont
I've got nothing against hid kits at all, I've had them in my last 2 volvos and the 406 that i had for abit and they were brilliant, hence the reason i bought a set for octy but in my opinion they just didn't work or at least the kit I bought didn't,
I wish they did because even with decent bulbs in the octy headlights are ****
I've got a spare set of headlights and was going to see if i could fabricate some low beam projectors into where foglight projector is but its one of many things on list and just not got round to it, either that or just get a bare set of standard xenon lamps and put my own kit into them
I think hids direct have revamped their kits now, ( touch wood ) ive had no issue with mine bud ,and ive had them on nearly 2 years....ish
please think about dazzling other drivers before you purchase these ... that's all i have to say :thumbdown:
The blues brothers wore sunglasses at night
Maybe thats why lol
Still plenty of flash cars like ranges, mercs that dazzle the foork outta me with there overly bright HIDS in projectors so it aint just reflectors.
Im game with hids in Projectors, they looks loads better.. However. i ran bi-xenon kit in reflectors for a while in the bora before i got projectors. i simply adjusted my head lights correctly, then a tad lower (on the lowest manual setting) and i never got flashed. if i needed them higher in the country i just just used the dash switch to make them higher.
Yes you should have projectors, but there are ways of improving/reducing the glare to other road users.
