**** URGENT **** - your help please - VCDS Fault Code
Changing comfort indicators from 3 to 4 flashes on an Octavia II this afternoon with VCDS.
Exit VCDS. Unplug OBD plug and turn key back to OFF.
Go to start car after glow plug lights gone out and it won't start. Lights flickering, not turning over.
MFD displys FAULT ESP and steering wheel light illuminated:
Run a fault scan and errors as below - (NB wiper motor error - 09 Central Electrics present on pre-changes scan)
Any thoughts? Couldn't find anything on the Ross-Tech wiki
Thursday,01,March,2012,18:00:43:26358
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72
VIN: **********************
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 TC HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 2048
Revision: --H11--- Serial number:
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 73EECFEF12AE09B
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B401C092800FBC80F02E890190082310000
VCID: 7AF0E2CBF5C4783
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
VCID: 830E1F2F0A0EB9B
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0573
Revision: 00103 AF
Coding: 4E180ABAF85BB1C040080080110011E4437000AE626D85605C0540000000
VCID: 32600AEB6D34403
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 02110 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 031109 05 54 0402
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
1 Fault Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 37
Mileage: 40712 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
OFF
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66640930802217
Coding: 100001
VCID: 40845023D398E23
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q8 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2GP5DO
Coding: 0020792
VCID: 3D7A29D7646A8FB
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78F4F8C30BC86A3
Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 00000128
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 943 G HW: 1Z0 920 943 G
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 410F00
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3D7A29D7AC6A8FB
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B020659
Coding: E9A1FF06000202002303
VCID: 69D2AD874062C3B
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAD0528B0D64483
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1102
Revision: 00005000 Serial number: 00000000000000
VCID: 2F66039FBE066DB
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2114
Coding: 0005118
VCID: 76E8F6FB01DC1C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 316205E7A8327BB
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Battery Volts: 11.2 V
PD
Temperature: 27.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0005118
VCID: 489448033BA8DA3
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1507610
VCID: 346C0CF357204E3
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8178633
Coding: 0D0004000001
VCID: 356A31F79C5A57B
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 32600AEBAD34403
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336E0FEF522E49B
End ---------------------------------------------------------------------
It must be something you have done, go back and re-trace your work and restore the values you changed.
Long shot but try disconnecting the battery and then trying again.
Looks like a coding error, did you make a note of the coding before changing anything. I would change it all back and see if the problem is resolved.
Battery related. RAC on-site. 540 cold cranking amps battery reading 86 cold cranking amps :wonder:
No coding alterations carried out other than the comfort indicators. Changed this back. Re-scanned and same as above.
Essentially the battery has gone very flat, very quickly :(
Have you got a genuine cable?
:yes: Yes indeed.
Panic over. The car is started and running.....
Battery connected to RAC van for 20 minutes and it's back to "almost full strength".
Recommendation from RAC to take it for a drive for 10-12 miles to fully recharge.
I'm puzzled as to how the charge drops so rapidly???
Sounds like me last weekend, just got vcds so spent a lot of time playing, came to start car Sunday evening and wouldn't start, got a whole raft of fault lights on dash and panicked for a moment. Then thought about things and stuck the jump leads on to the wife's car and started first time.
What I will say is the battery on my 2.0 TDi pd scout is nearly half the capacity of my mates mondo tdci which seems a bit suspicious!
Did the car have either DRL's on or Auto lights on?
Wont take long to drain the battery with the lights on.
I have found on one or two occasions when messing with VCDS, the electric power steering has become energised. Only noticed it literally a few times before but the electric steering is easily the biggest consumer of power with maybe the exception of the starter motor. Maybe it was something like that?
Just out of curiosity, did you actually manage to change the comfort indicator flashes from 3 to 4 on the Octavia?
Took delivery of my new 12 plate L&K on Wednesday, and tried changing the comfort indicator flashes from 3 to 5, via the adaptation channel, it stored the new value of 5, but when you try the indicators they still flash 3 times, any ideas?
A stab in the dark but try disabling comfort indicators then re enable them.
As it happens, no. Changed the coding back as a precaution after not being able to start my fathers car :(
