I'm looking to get stiffer through the corners but I'm having a bit of trouble finding the right bars to do the job. At the moment I'm running Koni FSDs with Eibach springs, Whiteline front and rear sway bars and Anti-lift kit but I'm still not satisfied with the amount of body roll I'm getting through the back end
(bear in mind I drive an estate).
What should I be looking at next?
I'm hesitant to go the a full bush kit as I already have a ton of NVH from the torque arm insert (dog bone bush)... But it's there as a last resort.
Has anyone investigated the RS-P braces and found anything? (see attached)
I think that this set-up may have been a one off custom job, but I thought I'd ask around before I go trying to find brackets, tearing up the interior to find mounting points and cutting up bits of carbon piping!
Any help or thoughts on the subject would most appreciated.
Edited by Fireside
FSD and Eibachs are quite a soft setup, I would suggest you need to change your back shocks/springs to something stiffer.
as above, you could try upgrading to bilstien either B6 or B8 (shorten) stiffer shocks but the trade off is low speed ride will be harsher
