How To: OCC DIY Guide Install
OCC Installation Part 1
Hi Folks, Reposting odd thread that was never posted to Techi section.emoticon-0102-bigsmile.gif
Pic of the hose used which is lined to stop oil breaking down the silicon.
Pic of the OCC , T piece, Joiner / connector
Bracket for OCC (already bent to allow fitting to slam panel), and hose clips at the ready.
Front plastic cover removed exposing the nuts and bolts to remove to allow slightly better access to the plastic hose.( I will refit this as like the way it covers the other hoses)
Carefully pull the bracket out the way and at the same time unclip the dip stick and also unplug the sensor that is underneath this metal bracket
Pipe highlighted to remove
Pipe removed.
Can see the goo in the T piece, cleaned this out as best as I could.
Remove the Y pipe.
DV removed and pushed to one side to expose the valve the new hose will be connected to.
Parts used to fit new hose to the T Piece. (note joiner cut down slightly to allow full insertion into T piece)
New hosed fitted.
Area highlighted for OCC to be fitted.
Fitted OCC with bent bracket to allow correct positioning of OCC. Bracket fitted underneath the slam panel to look more oem.
New hose connected to the Valve and DV refitted.
Refit the metal bracket removed earlier and remember to re plug sensor and re fit plastic cover.
OCC Installation Part 2
where'd you get the can and kit from as looks good and like the fact its black
What size silicone did you use? Saves me getting my verniers out
19mm internal diameter. It was fluoro lined silicone hose also.
  • 6 months later...
great piece that, is there any harm in going to atmosphere with the final hose from the oil catch, instead of back to the tip? my old school experience with bikes etc, is to stop the crank case gasses from being re-breathed by the engine....... at the cost of some oil smell on occasion
How much hose did you need mark?
Hi there these systems are closed loop. If you were to vent to atmosphere you would get massive build up of pressure in the bottom end. To overcome this you would need to get a 25mm outlet to vent to atmosphere to get pressure out quick enough. With these breather systems you will also get loads of oil vapour that will smell big time mate. I looked into it too and it seems with my investigation not recommended.
Approx 2 metres buddy to be safe.
Planning on doing this next week. Quick question though, see the t-piece pipe that sits under the manifold, and has a small pipe running up to a nipple on the inlet manifold. What do you do with that section once you take out the t-piece and make a straight through part. Is it a case of just blocking off that nipple, or will I have to run a pipe from it to anywhere?
Or should I just keep the t-piece in until i do further deletes? As its completely standard at the moment apart from Creation motorsport pipes being put in, pipes which have that t-piece built in.
Edited by Saints92
  • 10 years later...
Bit late this answer but as I'm doing this right now-
this 'how to' assumes you've done the SAI delete, which involves taking that feed from the nipple and running it up to the top of the divertor valve. I know cos I've just bust my DV in the process! So the 'T' piece becomes redundant.
Just in case anyone else is doing this install these days
no I think that's my mistake...there IS another short pipe from the 'T' which leads back to the left-hand side of the manifold, god knows what I pulled out of the right-hand nipple, can't recall where it led to. Car seems to work ok though. Isn't there a pipe coming from that area which relates to the brake booster?
Apologies I've had my face in the engine bay all week doing the deletes/catchcan and all these pipes start to look the same.
Don't want to dish out incorrect information
