columbus sat nav surround
good morning guys/girls
i hope someone can help ive fitted columbus sat nav to my 54 plate mk 2 octavia ive got 2 issues with it and was wondering if some one can help me
1) the stereo is alot smaller and need to order a pre face lift surround does anyone know the part number i can get the face lift one but not the pre face lift ??
2) the stereo seems to have a fan running on in the unit which is causing a battery drain does anyone know if theres a coding change or should i have fitted anything else to sort this ?
many thanks for your time
gavin
Hi Gavin, Can't tell you what the part number for the surround is until I get home and check the paperwork from when I got mine. Battery drain is a known issue and requires a replacement CAN gateway to fix - have a search on here, its been discussed a good few times. EddieNL may be your friend here as he has supplied CAN units previously I believe. Cheers, And.
Edited by Anddenton
brill thanks ill get in touch with the chap and see what we can do many thanks again
  • Dash trim for MFD2/3 with Climatronic (black) - 1Z0 858 069 C 9B9
  • Dash trim for MFD2/3 with Climatronic (silver) - 1Z0 858 069 R 2AU
many thanks for the part numbers ive ordered it but its not right , the hole around the heater controls a/c button and rec' is to big, i wont the small one in the middle can anyone help many thanks gavin
You need the equivalent one for the manual/climatic aircon, let's see if there's a part no for it in the useful parts thread...
Edit: no there isn't, you might have to have a chat with the parts desk at the dealer to see if they can identify it, as the part definitely exists.
If not, I know Brimma has one in his Octy...
Just fitted mine today had the surround waiting for the job :D
thnaks for replying i work for a skoda dealer and carnt find it for love or money would you be able to speak to brimma and see if he has the part number many thanks gavin
Try these.
1Z0 858 069 B 9B9 - Trim for climatic switch for vehicles with navigation system satin black
- £4.76
1Z0 858 069 F 9B9 - Trim for climatic switch for vehicles with navigation system satin black - £4.76
