Tyre wear !?
Hi sone of you may know i recently bought a mk1 fabia vrs ... Anyway bought it fitted with 17" bbs alloys and coilovers, anyway im having trouble with tyre wear on both front tyres the inside edges are lastin maybee a month or so and the outside edges are virtually brand new so the car is running way too much negative camber so my question is are there a company that do camber adjustment kits for the fabia or is there something else i need to look at .. All help appreciated thanks
If it is only the fronts, I'd get the tracking checked first & foremost. Then perhaps a full alignment / geometry check if that doesn't solve it.
Go and get a full geometry set up will cost about £50
Nobody makes camber kits for the VRS as far as I know
But a full alignment will save you a fortune on tyres :)
What bbs you running :)
yeah ill check the tracking tomorrow with my works stone age tracking rods lool ..... i doubt there accuracy if im honest .
and johnny i dont know the model what theyre called but check my build thread im just about to update it actually
Your works dunlop tracking gauges won't tell you much
Need laser alignment and geometry.
Cool I'll have a look :)
