octavia brakes staying on
brakes are free as.drive 5 mls and their coming on changed the rear calipers all four flexi master cylinder ran car with servo &abs pump disconnected still the brakes are jamming.at my wits end any one help
all four brakes sticking or just front or rear?
try undoing the fluid cap when the brake/brakes are stuck on and see if they free off
Edited by petetdi
  • 4 weeks later...
I had this problem on a rally spec Escort RS2000. I had been working on the brakes and adjusted the free play on the master cylinder - as a result the piston wasnt coming fully up which it needs to do to release the hydraulic fluid pressure.
Your symptoms sound identical. I'd check around the master cylinder.
