turbo problems
ive noticed lately that when the turbo spins up from low revs i get a short sqealing chirping type noise, the car then drives as normal but it worrying me. ive read a few things about this problem on other forums inc this
flutter as in chirpy noise like cossies used to make or a woosh?
chirp/flutter is compressor stalling, and a non-functioning recirc dv = bad news for the turbos lifespan
im not sure if this is my problem it sounds very much like it, this was off an audi forum so some more skoda knowledge on this would be great.
the car has 71k on it , is running shark stage 1 and a k&n panel filter i also replaced my dv valve witha new style piston type, im going to read the engine codes with my shark sts ill add them to the post later.
all advice gladly appreciated
fault codes are
P0196
P0299
P3137
P0642
anyone!
Its prob just a noise ur getting through ur new dump valve.
the dump valve has been on about a year and a half now, im going to jack it up when i finish work this week and give it a good dose of looking at
the car is in the garage to get diagnosed also checking aircon syatem which is very noisy , if i need a new turbo and compressor its getting traded in .
  • 8 months later...
epic thread revive, but both problems above are now sorted the turbo noise was the type d dv valve not holding the boost swapped for a type c and now ok.
The noisy aircon just needed a regas, which was done at my local kwik fit for £30.
just put his up in case people do a search for similar problems!
