What bhp can i acheive
yeah just use it as a guide so +/- 1 psi is acceptable
  • Replies 79
  • Views 5.6k
  • missingmyvrs
    missingmyvrs
    your missing the point the restriction on these cars is the down pipe !!! a cooler will enable you to run more boost as it wont heat soak or cause high inlet temps but catch 22 you wont be able to ru
  • RS Tunings rr is one of the more realistic ones out there and if anything under reads. It is 300 lb ft, like I say its been fettled constantly over the last 3 years at least. Mine was 262 lb ft.
  • oops, meant to say cupra R, also as mentioned TT and r32 ones are the same
cool so working on that she would be 11 psi peak and 9 holding. so she must be standard by a country mile.
Reason i have the cai and forge 007p is because i like the noise!
Handling will be sorted via coilovers, unsure what to get, choices are galv weitecs, galv v1's, stainless v1's or eibachs
Cheap ebay decat then get your Cat welded in ;-) the Cat isnt the main restriction !!
Agree with above its all about the handling and stopping !
Ok so if irrc the standard dp is very thin! So just widen up the dp will give I assume better throttle response by allowing the turbo to spin up faster etc? I've stepped away from full systems and more power etc due to cost and the fact I kind of like having a quiet comfy car for once!
A quiet comfy car can be maintained if you mod thoughtfully - you can infact make your car more comfy and quiet.
