Columbus help
Hi, this has been covered elsewhere but I'm not sure whether I have a pre fl or fl Octavia. It was registered in jun 08. I'm looking to update to seven digit postcode searching on my Columbus head unit. I know I need to check my existing part number and update firmware according to that but will i also need to worry about the battery drain I've seen referred to?
Thanks in advance
Adam
I would say you have a pre fl model. Is the Columbus already in? I would say you shouldn't have the battery drain issue, but you should get someone with vcds to check.
you will need map 7 onwards to get 7 digit postcode searching , so update your map first as you need this anyway (use a space or two when inputing the post code to make up the full 7 digit postcode if needed ie;- n111df won't work n11 1df will) if you find the new map not letting you put full post codes in then update your firmware and can gateway if needed
Many thanks for this both
