Average vRS Oil Temperature
  • Replies 51
  • Views 13.4k
  • BonnevillevRS
    BonnevillevRS
    You deem 110 degrees as the upper limits of acceptable? Most good quality oils aren't even into their stride by then! A good quality oil gets better with heat, not worse! Its why Audi lock their V8 e
  • BonnevillevRS
    BonnevillevRS
    The minimum your oil temp will be on this engine is 90 degrees as it is a coolant cooled heat exchanger, so when your coolant is 90 degrees at idle your oil temp can only be as cool as 90 degrees if t
  • Auric Goldfinger
    Auric Goldfinger
    You need Petrol
Sent from my XT1039
