fabia vrs interior - time for a change!
Great work, obviously you're quite handy with this kind of stuff. Not seen blue calipers before either.
  • Replies 50
  • Views 15.4k
  • Due to do mine in my new vRS as they still havn't worked out a touch of colour (be it black/gloss black) makes a huge difference!
  • got the pics uloaded,not great cuz they from mobile but oh well. first thing i stripped interior so i could give it a good clean before new seats go in. the tt seats may have same runner system bu
  • quick picture from the colour change on the brakes
Any side on pics of callipers with wheels on?? As said above, not seen blue on fab.
not the best pics but...
been looking for black rear seats to match the tt fronts but nothing so far :(
did manage to get hold of a r32 steering wheel so that will be going on in the near future to finish the interior :)
Does the Fabia's airbag fit straight into the R32 wheel?
If so methinks I'll be after one too!! :-)
yea straight fit. just ordered new badge to replace the skoda one on steering wheel. hopefully get it on car during week and get some pics uploaded.
yeah
just been out fitting r32 steering wheel and changed the badges on back and on steering wheel.
steering wheel didnt take long to change left battery disconnected for 10min, then 10min to swap the steering wheels :)
turned wheel so hole at the back was at the bottom
insert screwdriver flick the clip to release one side of the airbag
repeat for the 2nd clip
airbag then free to pull forward so you can pull the firing plug from airbag.
insert m12 (i think that was size) spline socket for steering wheel bolt
pull steering wheel off.
ta da! :)
i changed the metal cage over on the wheels after reading the r32 cage sits a little bit higher than vrs one.
fitted new wheel with new badge and took for a drive to make sure wheel was straight
bingo!
New badge on the boot
Wow really good thread :) your car now has very unique interior but I think a lot of people will want to do the same haha you might just start a trend! I don't suppose you still have the old vrs steering wheel do you if you want to sell it? Also where did you get the black badges from as I have been looking for a set of those?
  • 5 months later...
bingo!
how did u change the badge on airbag? cos some say that's no possible, the original badge is bonded to airbag. I want to change my on non Vrs model
I believe gel resin badges as i've done it with mine, just stick it over the top... ;)
thanks I was thinking that as well, but wonder if can be remove compliantly :nerd:
Got some half leather TT seats to collect this week :rock:
just had a look through this thread, what a transformation!
How did you remove all the vents! Should of made a how to
just get a flat blade mate then pri them out slightly without damaging your dash board! :D
Looks really good so far. Hope you find some black rear seats soon
Just noticed that your puddle light is clear. I hate my red ones. Did you buy new clear lenses.. if so where from..
Cheers..
Edited by bazhuddy
Cheers..
the boot light out of the fab vrs also fits the doors, i have them in mine. you can get them off ebay, scrappers, tps etc.
Good thread mate nice work! Thinking about doing my interior plastic trims carbon wrap soon..
Matt, why the TT half leather, do they bolt straight in or are you doing some work to get them to fit, or is it ones someone has already put the work in lol
stripped all seats out today and gave carpet good clean, fitted the tt seats, new double din headunit, wired up the footwell leds to the doors. so they come on together, then rain started, calipers tomorrow hopefully,
pics to follow :)
Was the tt seat a straight fit?
I went for the TT seats because they were suppose to be a easy job. They are not though, angled bolt hold at the front need chopping and welding to be flat and strong enough to use again. Thankfully they were cheap & Unit 18 are great at a bit of on the spot fabrication.
