It's time for a FMIC - prices?
Hi there.
I know there's a lot of threads on this but.
Which would recommend? In guessing at Seat Sport?
Can anyone give me some links to get it cheap as possible?
Or other FMICs which you rate.
I know some people buy the cooler and pipe work separate to keep prices down.
Thanks. :)
Sorry for being a lazy f**ker. x
Sent from my iPhone using Tapatalk.
I've bought my pipe work from Demon Tweek's and a couple of bit's from Forge themselves and with the discount I get the pipe work has cost me £170 and I'm getting the intercooler from TPS for £237
Thats exactly what i was gona say ths cooler
Southy could you link me the pipe work?
Will do once I'm on my comp fella. Tweeks sell all the forge 45/90deg bends too so I bought them at the same time. I seem to recall without my trade discount it was around £170 ish but you can have them in any colour in the Samco range
Just to clear up the stuff from Forge was £60 on its own
Straight pipe section 51mm internal bore size:-http://www.demon-tweeks.co.uk/performance/universal-straight-hoses/samco-air-water-straight-silicone-hose
(this comes only in 1m length, you also need a small hose coupling which is 76mm long so you will have plenty from this section to cover that also)
Straight reducer section x 2 (63mm-51mm):- http://www.demon-tweeks.co.uk/performance/universal-straight-hoses/samco-silicone-hose-straight-reducer
45 degree bend 51mm internal bore :- http://www.demon-tweeks.co.uk/performance/universal-elbows/samco-45-degree-silicone-hose-elbow
You also need 1x45 degree Forge pipe bend and 1x90 degree Forge pipe as can be found here;- http://www.demon-tweeks.co.uk/performance/hose-joiners/forge-alloy-air-and-water-pipe
You will finally need a 90 degree bend with MAP sensor piece in it, I bought mine from Forge direct along with the bayonet couplings. These are expensive around £80 at retail price, but as I say I got trade through my work
Adam
I got the forge seat sport style fmic. Excellent bit of kit. Although forge messed up by not sending the brackets and some pipe work. All sorted by Ali at unit 18 though :-)
Another +1 for forges seat sport style! Also comes with larger bore silicone turbo outlet pipe which I don't think their fmicskint pipe comes with.
No issues my end, apart from a rubbing pipe on the driveshaft which forge replaced ASAP, I paid 535 fitted I think
